Create a uniform pattern BUT make sure the instances are in a Group, then right click on the pattern and you will have the option Unpattern, shift select all the groups and Ungroup if needed, now all the instances are independent features.
I used this method recently to create an Aero chocolate bar style pattern (you have Aero in the US?) - random hemisphere cuts into a surface.
