Goodmorning PTC,
I would to ask you if it is possible to read file name with some dots with creo parametric 3.0.
thank you so much for your usual cooperation.
best regards
Creo filename must not contain "." character.
MH
First to all,
thank you for your prompty reply, but I have the problem with my customer that requires a matriculation with file name contains a dot.
I'm trying to solve this problem also with another tool, compatible with creo parametric.
Do you know any tools useful for my scope?
thank you
Sorry, I forgotten to explain an important issue.I can export the file also in step format.
Thank you
I do not understand your problem well.
You cannot export STEP file from Creo and rename it in Windows Explorer ?
MH
you are right, I try to do a better explanation,
I have to deliver a .stp file related a big assembly and sub-assembly, with much parts in to them, where the requested matriculation shall be with dot in the file name
(e.g. RT.100.00.500).
The best way would be that to rename the file directly in creo parametric, but it's not possible.The other solution could be to rename with software destination, but this solution requests much time in order to perform this operation.
Do you know a easier method in order to solve this issue?
thank you again
I did following test:
MH
