removing names, etc from a file...
ptc-356958
I am having an issue with a part file where an external piece of software (Jerand) uses a coordinate system named fp0. If I delete this coordinate system (due to a mistake or reconfiguring a part) and replace it with a new coordinate system the name will no longer be fp0 and I cannot rename it to fp0 as the file tells me it already exists (for those who know this software, this is not a case where the coord sys still exists in the generic, when I delete it, I delete it).
Anyway, is there a method of purging the pre-existing name from the file?
Incidentally, I notice that this same problem existed in 2001, went away in WF2 and has reappeared in WF4.
Hi Peter
A work around could be to rename the csys before you delete it.
/Bjarne
Peter Woerner <->
17-12-2010 19:02
Please respond to
Peter Woerner <->
To
cc
Subject
[proecad] - removing names, etc from a file...
Site Links: View post online View mailing list online Send new post
via email Unsubscribe from this mailing list Manage your subscription
Use of this email content is governed by the terms of service at:
