rendering external software
gbon
Hi all's,
I'll need to make rendered animations based on proE files and other 3D files
purchased on Turbosquid.
It seems to be too complicated to import bought 3D files in proE and using
Pro/Animate.
Si I've planned to buy an other software that is more able to render
animations.
At the same level of prices, I found 3DSmax, Maya, Cinema4D and lightwave.
There is also Blender that is free.
I've tried blender and I can import ProE files.
However, I don't know how I will be able to import Turbosquid files.
Theirs files seems to be better for 3Dmax or Cinema4D.
So any advice on which software I should buy would be welcome.
What's working well or not.
GB
Another software you may want to consider is KeyShot. I have played with the 15 day free trial on the advice of others, and found it to be easy to use and works with native Pro/E files.
