Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
rendering...
nrollins
rendering...
Is there a simple answer to why the on-screen preview - even at high quality
- looks "acceptable", but when I render to a TIF, I get a washed out image -
like I am looking through heavy fog...?
(rendered output - TIF file)
(rendered output - Full Screen)
I really do hate Pro/Render. It seems to defy the definition of insanity...
(insanity: keep doing the same thing and expect different results...)
(pro/render : keep doing the same thing and get different results...)
Sorry for the mini rant. Thanks for reading.
-Nate
Nate,
Rendering, you got to love it. The simple answer is No.
What you see is fairly common amongst many renderers. Preview rendering
is just that, a quick shot of what the colors/image may look like, where
the lighting falls and where the camera is pointing. Not to mention
texture map appearance, bump mapping, hdr alignment, etc....
For most good renders expect to tweak until the output is right or until
you get sick of tweaking. Do a test render with lower quality settings
and at a smaller resolution until the light, color, camera, etc are what
you like and then crank them up to full. Your sanity will appreciate
you for it.
Brian
Looking at the images, it looks like it can be corrected by changing the
gamma values. This can be done in an image editor. Also, just for the
heck of it, I did a search in the options dialog for "gamma" and found
an entry:
window_gamma Gamma correction to apply to images created by renderer.
Default value is 1.0.
Try it.
Paul
Nobles, Brian S. wrote:
> Nate,
> rendering is just that, a quick shot of what the colors/image may look
> like, where the lighting falls and where the camera is pointing. Not
> to mention texture map appearance, bump mapping, hdr alignment, etc....
> until you get sick of tweaking. Do a test render with lower quality
> settings and at a smaller resolution until the light, color, camera,
> etc are what you like and then crank them up to full. Your sanity
> will appreciate you for it.
> Brian
Isn't that the very nature/definition of rendering?
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
I agree that you should look into the gamma correction.... Another
suggestion, if you like the result from the render to screen.... simply
do a print screen and capture it. I have done this in the past as well.
Jonathan Hadley
Senior Design Engineer
Grakon LLC
