hello people
i have a question
i draw a part screw_p2319024
it is posible to make same name in drawing name without type on keyboard same name?
i want when creating drawing file that have the same name as part of Automated
is posible the drawing have name screw_p2319024
Bogdan,
you can use AutoIt. For inspiration see Re: Creo 2.0 - Open a drawing from active part?
Martin Hanak
Try this mapkey: How to create a drawing with same name as active model with Mapkeys
Unfortunately, there is no current functionality for this. The following document looks like it might work for you but I'm not sure how practical it is.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS37133
Bogdan,
This works for me and hopefully the same for you.
First off, I received this from nicomajstr, a mcadcentral user.
I requested the original files which ran on WF4 and modified them to work within Creo so the kudo's goes to his (her) effort.
To make this simple, create a folder path:
c:\home\programs
and put the two files attached - unzipped, of course, in the programs folder
once you understand what is happening, you can change the file paths in the script to where you want.
in your config.pro, put this script:
mapkey std @MAPKEY_NAMECreate new drawing with a format;\
mapkey(continued) @MAPKEY_LABEL>Create New Drawing;\
mapkey(continued) ~ Command `ProCmdModelSaveAs` ;~ Open `file_saveas` `type_option`;\
mapkey(continued) ~ Open `file_saveas` `type_option`;\
mapkey(continued) ~ Select `file_saveas` `type_option` 1 `db_563`;\
mapkey(continued) ~ Activate `file_saveas` `Current Dir`;\
mapkey(continued) ~ Activate `file_saveas` `SAB_c:\\home`;\
mapkey(continued) ~ Select `file_saveas` `ph_list.Filelist` 1 `programs`;\
mapkey(continued) ~ Activate `file_saveas` `ph_list.Filelist` 1 `programs`;\
mapkey(continued) ~ Activate `file_saveas` `OK`;~ Activate `shd_img_param` `OK`;\
mapkey(continued) @SYSTEMstart C:\\home\\programs\\ustvari_risbo.bat;\
mapkey(continued) ~ Command `ProCmdRibbonOptionsDlg`;\
mapkey(continued) ~ Select `ribbon_options_dialog` `PageSwitcherPageList` 1 `ConfigLayout`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `ConfigLayout.Open`;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;\
mapkey(continued) ~ Input `file_open` `opt_EMBED_BROWSER_TB_SAB_LAYOUT` \
mapkey(continued) `C:\\home\\programs\\`;\
mapkey(continued) ~ Activate `file_open` `opt_EMBED_BROWSER_TB_SAB_LAYOUT`;\
mapkey(continued) ~ Command `ProFileSelPushOpen@context_dlg_open_cmd`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `OkPshBtn`;\
mapkey(continued) ~ Activate `UITools Msg Dialog Future` `no`;\
mapkey(continued) %usdrw;.;.;.;.;.;.;.;.;.;.;.;
fire up creo
open an assembly or part that does not have a drawing and run "std"
all the ".:.:" after %usdrw is an auto filler for the drawing form that has parameters. adjust or remove as needed.
enjoy
Hi RonSt. Pierre Marble.
I have a problem with your script. It creates a tiff image with the same name as part file and for the drawing it's asking me to type the name for drw. What i'am doing wrong? I don't understand what i must adjust %usdrw.
