save asm. as a .OBJ (wavefront file)
martidj
Gurus!
I am trying to save a large assembly as an .obj file. Asm. contains
many hundreds of quilts (cosmetic features, imported copy geom., etc).
Finding and selecting them all in a nice reasonable fashion is what I am
looking for insight into. I can't believe I have to select hundreds of
these one at a time!
Thanks in advance
Dave Martin
Sr. Industrial Designer
The Toro Company
This electronic message including any attachments ("Message") may contain information that is privileged, confidential and/or exempt from disclosure under trade secret and other applicable law. If you are not the intended recipient, notify the sender immediately, permanently delete all copies of this Message, and be aware that examination, use, dissemination, duplication or disclosure of this Message is strictly prohibited.
4 REPLIES 4
David,
you can use the SearchTool (Ctrf+F) for this. Switching to the Search
Tools History tab and mark Rule "All" will allow you to find all Quilts in
one go.
If your quilts have been given names you can also use the Attributes tab's
Name rule, but Quilts do not have a default name, so most likely this will
not give you what you need.
Good question. I now learned that Quilts can be exported to .obj. Thought
is was only solid geometry that could be exported to a tesselated format.
Bjarne
"David Martin (Lyndale)" <->
04-05-2010 21:51
Please respond to
To
cc
Subject
[proecad] - save asm. as a .OBJ (wavefront file)
Gurus!
I am trying to save a large assembly as an .obj file. Asm. contains many
hundreds of quilts (cosmetic features, imported copy geom., etc). Finding
and selecting them all in a nice reasonable fashion is what I am looking
for insight into. I can?t believe I have to select hundreds of these one
at a time!
Thanks in advance
Dave Martin
The Toro Company
Site Links: View post online View mailing list online Send new post
via email Unsubscribe from this mailling list Manage your subscription
Use of this email content is governed by the terms of service at:
amedina
(To:martidj)
In a related issue/topic. Unnecessary knowledge really. I don't know how
good you are with programming but you could make it into a map key. Even if
it is not a single click map key, it would still help you out. let me
explain;
For a large assembly, I figure that at some point some assemblies are so
massive that very few programs out there can actually open the single OBJ
file. However if you import one by one the parts you want, it is easy to
open a dir full of OBJ files from say Blender or any other program that
supports it. I usually run it and just watch the computer look like I'm
doing something important. So the key is to have good OBJ resolution but to
export part by part so that solids stay solids and parts are not
automatically created just because a solid is separated in three pieces. It
helps with other stuff too.
regards,
Alfonso
On Tue, May 4, 2010 at 11:17 PM, Bjarne Frandsen <->wrote:
> David,
> you can use the SearchTool (Ctrf+F) for this. Switching to the Search Tools
> History tab and mark Rule "All" will allow you to find all Quilts in one go.
> Regards,
> Bjarne
> *"David Martin (Lyndale)" <->*
> 04-05-2010 21:51
> Please respond to
> To
> cc
> Subject
> Gurus!
> and selecting them all in a nice reasonable fashion is what I am looking for
> insight into. I can’t believe I have to select hundreds of these one at a
> time!
> Thanks in advance
> Dave Martin
> The Toro Company
mf2001_98
(To:martidj)
Quilt can be exported in the .obj format ?
Please, could you explain how to do this?
Thank you very much
Marta
David,
one go.
Bjarne
04-05-2010 21:51
Please respond to
To
cc
Subject
Gurus!
at a time!
Thanks in advance
Dave Martin
The Toro Company
http://portal.ptcuser.org/index.php?module=sthtml&op=load&sid=s1_010_tos
Add the Quilt to the Export Group in the Wavefront Export dialog. Use
Query select to get the actual quilt instead of the part.
Then select a CSYS for export reference.
/Bjarne
marta floryn <->
26-05-2010 14:37
Please respond to
marta floryn <->
To
cc
Subject
[proecad] - RE: save asm. as a .OBJ (wavefront file)
Thank you very much
Marta
David,
one go.
Bjarne
04-05-2010 21:51
Please respond to
To
cc
Subject
Gurus!
at a time!
Thanks in advance
Dave Martin
The Toro Company
