scale display in ratio
dbolden
8-Gravel
How do I get my detail views to display their scale in a ratio format as opposed to decimal?  I went into drawing properties and changed "view_scale_format" to ratio_colon. THis didn't work.  I tried changing "detail_view_scale_factor" and this didn't stick.  It changed back to 2.000.  I want my detail views to say "Detail A  Scale 2:1".
Also how do I change the hatch pattern to a denser pattern?  In the detail view it is barely recognizable that there is even a hatch.
two changes to .dtl file
view_scale_denominator 100
view_scale_format RATIO_COLON
With regards to denser pattern,
select the hatch pattern, RMB > Properties
select x-component, spacing, hatch, overall, half.
if you continue to select "half" it will make the pattern "denser".
You may also enter a value if you so choose.
