scale issue
A_CASHEN
scale issue
Gurus,
A coworker of mine has an issue with a particular datum being MUCH
larger than the rest of his model. Of course, this affects default
views and is just annoying. Can anyone tell me how we might fix this?
There are no other suppressed parts that are off in space causing this.
Thanks in advance.
Amy Cashen
Engineer II
The Delfield Company
Manitowoc Foodservice
T 800.733.8821 x12634 | F 989.773.1588
Integrity, Commitment to Stakeholders, and Passion for Excellence.
kkja
(To:A_CASHEN)
Select the datum;
right click;
edit definition;
select the display tab;
click adjust outline;
you can then select an actual size or choose a reference feature for the datum's relative size.
Jeff Cool <><
Trane
Ingersoll Rand
Tyler, TX 75707
903-581-3352
Chris3
(To:A_CASHEN)
Right click on the Datum -> Edit Definition. Adjust the size or uncheck
"Adjust Outline"
Chris
Thanks for Jeff and Steve. This fixed the problem.
Amy Cashen
Engineer II
