Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
At a previous job, whenever a new drawing was created, it had pre-established views already setup in the drawing (Front, Side, Top, etc). Can anyone tell me how this was done so I can set up my drawings this way?? I'm using Wildfire 3.0. Thanks. This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
Hello Create a new drawing file, de-select the default template check box, pick empty, press OK, go to "Applications" on the top tool bar, and pick "Template", then go to "Insert" on the top tool bar and pick "Templete View" from there you can create all your custom views, dims ect.
The front, right side, and top will be the default views if the part is active before you open a drawing file, but with the afore mentioned you cam custom make views.
