sheet metal
ptc-1423219
2-Explorer
sheet metal
How can I create a sheet metal drawing with 2 sheets so one sheet has the flat pattern and the other sheet has the bent form?
Randy, First of all, you should create your flat pattern using the Flat State command under the sheetmetal setup. That will add the flat state as an instance in a family table, with the generic being the formed (bent) state. In the drawing, add a model. In the case the new model is the flat instance. Then, for example, the 1st sheet can be for the formed state and create a 2nd sheet for the flat state. Make sure you switch model to the desired state before adding views.
