We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
What determines 'zoom' of object when view default
msteffke
What determines size of object in screen when you 'view default', or hit
that little magnifiying glass tool button? I want to use
ProRasterFileWrite to dump a tiff of a shaded model. However the model
is always zoomed out too far. And is there a way to zoom the assembly
in closer prior to the rasterwrite?
Thanks for any idea,
Mark Steffke
You need to use ProViewMatrixSet() to set the zoom of the current view. You can specify a zoom value in the new matrix that you use. Read the API Wizard under User's Guide->Graphics and Object Display->Solid Orientation and additionally User's Guide->Coordinate Systems and Transformations->Coordinate System Transformations. The latter will explain the contents of a matrix.
Patrick Williams | Engineering Systems | Sr. Applications Engineer | Steelcase Inc. | 616.698.4078
[cid:image003.jpg@01CA78BD.E2AD4A00]
msteffke
(To:msteffke)
Thanks Patrick, I'll mess with this a but and see how I like it.
Mark Steffke
