wf4
In sketcher mode, is there a way to make several dimensions of equal value? If you look at the attached example, is there a way to make one 1.5 dimension equal/dependent on the other 1.5 dimension?
thanks. i think sketcher relations will do the trick
i see the difference. construction lines are definitely the way to go!
