software to convert Pro-E file to customer required file
ptc-3233571
Hello every one, I have a proe part with 34 MB and i have to send it to a customer who require a STP file format and it must be in KB`s . Is there any software which can convert the proe part to a step file of 5 kb (for eg.,) Thanks in advance, Kathir.
4 REPLIES 4
In Pro/E: File>Save a Copy then choose STEP as type of file...
Try using Winrar and maximize the compression.
Thanks for the reply. But this is not i require . I will reframe the question. Is there any software to convert Proe- Model into a low size model in terms of kb and also i have to make logic combination with using those parts what i have created. Previously there were software like Modularis and CAD-click but even if we convert it we cannot make it independent. That is it requires a source file , if we delete the source file in PRO-E we cannot access it. Please do suggest any answer. As iam in desperate need of it. Thanks in advance.
You can maybe try eDRAWINGS.
