Guru's:
I have a multi- sheet assembly drawing with multi-BOM's (instances of an assdembly generic). The bill's come into the drawing in numerical order, ie item 1 is part number 001, item 2 is part number 002. etc. I would like the BOM to reflect the actual assembly model BOM sequence. I know to use Repeat region/sort region/clear all to convert the numerical order back to the actual order. BUT this time the "clear all" is greyed out and I can't use it. Can you tell me why the "clear all" is greyed out and what i can do to change it??
Joe
