adding draft on the letters and like to space them apart and letter are .500 tall ,
I don't think there is any "spacing" option to control the text in a sketch other than aspect ratio, but that stretches the letters too.
You may have to do individual letters.
I was using the text box do letters ( front3d ), but I see I can not space the letters out in difference space dimension. like if the letters is .050 .
I use the letters text box ,per letter . then I adding draft to the letters each letter.
I there way I can take each letter with the draft (extrude ) and make a library . then just pull them on my model ?
after put the letters and number on the model with the right space that look good . then I can print the part on a 3d printer.
thank for the help
