I have following relation in start asm template:
/*CONTROLLING CALIPERS RAL2004
if NAME=="CONTROLLING CALIPER"
RAL="2004"
endif
then I have a parameter CUSTOMER
i would like to add another reralion(s) like this:
if CUSTOMER is "JD" and NAME != "CONTROLLING CALIPER"
RAL="5018"
if CUSTOMER is "VL" and NAME != "CONTROLLING CALIPER"
RAL="5008"
else
RAL="5012"
can anybody help to make it work?
Thanx in advance
T.
Tomas,
simply replace your relation with my. It must work correctly.
/* NAME is equal to "CONTROLLING CALIPER"
RAL="2004"
else
/* NAME is not equal to "CONTROLLING CALIPER"
if CUSTOMER=="JD"
RAL="5018"
else
if CUSTOMER=="VL"
RAL="5008"
else
RAL="5012"
endif
endif
endif
MH
use following relations:
RAL="2004"
else
if CUSTOMER=="JD"
RAL="5018"
else
if CUSTOMER=="VL"
RAL="5008"
else
RAL="5012"
endif
endif
endif
MH
Hi Martin,
Thanks for your quick answer.
There is a problem with CONTROLLING CALIPER - if the parameter NAME is CONTROLLING CALIPER the RAL must be 2004 no matter which the CUSTOMER is.
T.
Tomas,
RAL="2004"
else
if CUSTOMER=="JD"
RAL="5018"
else
if CUSTOMER=="VL"
RAL="5008"
else
RAL="5012"
endif
endif
endif
MH
IT WORKS...
THANKS A LOT
