Hi
I'm trying to create a small surface on a large surface for machining.I've created a sketch on a plane then copied and pasted the surface i require then projected the sketch onto that surface,I then tried to trim the surface but the trim option is greyed out,I must be doing something wrong
Thanks mick
Michael,
mill window is available for surfacing if that would work for you? you could create a window of the small surface area you are trying to machine. same as your sketch.
Steve
Hi Steve
My surface is on a steep angle and as hopeing to use cutline surfacing so I can just use a normal step over. In mill windows it steps down to much
Mick,
just take out the step down with a dash(-) it should just make one pass on the surface.
Mick,
Here is an example surfacing with a window I am talking about with a steep wall. Just set the step depth to a dash and it will only make one pass. I use it all the time.
Thanks Steve
That does work but was just trying a different way by just creating a small patch surface. I projected a sketch onto the surface but don't know how to trim surface leaving just a small surface.
Thanks mick
Just a simple thought:
Did you project the sketch directly onto solid surfaces? Then you will not be able to trim, as it would "open" your solid.
Make sure you copy the surfaces you want to trim and then project the sketch onto the copied surfaces (quilt). If the sketch is closed or ends on the surface boundaries, it should work.
Thanks for your help Gunter I will try that
mick,
this is how I would do what you are trying. I would copy the surface then extrude a surface through the copy, then trim to get the inside of the copied/ trimmed surface.
hope this helps.
Steve
