sweep done in older version
SkyKing
How come sweep done in older version (wildfire 5) not working in newer version (creo 3.0)?
3 REPLIES 3
dgschaefer
(To:SkyKing)
We need some more information.
Are you saying that you have a model with a sweep that was created in WF5 that won't regen in Creo 3 or that the workflow you used in WF5 isn't working inCreo 3?
Either way, more details or a sample model would be helpful.
LinkedIn
The model first open fine. When I go to change some dimensions on another feature that is not related to the sweep, the sweep feature fails when models goes to regen. To fix I redid the sweep.
dgschaefer
(To:SkyKing)
Could be a lot of reasons, but I doubt that it has to do with Creo 3.  Without seeing the model, it's hard to say.
Glad you got it fixed.
LinkedIn
