threaded hole spec callout
FredMatthis
My supervisor and I are having a "discussion" about how a threaded hole or shaft
should be shown on a drawing.
We would like to know what is the correct way to show the thread call out
on the drawing.
1) 1/4-28 ( with a fraction)
2) .250-28 ( decimal w/o the diameter sign)
3) (diameter sign) .250-28 (decimal with the diameter sign)
Does anyone know what is the correct way?
Does any one know what spec describes this, so I can prove it?
Pro-e shows it as a fraction 1/4-28
Can this be changed if required??
Thank you for your assistance in advance.
Fred J. Matthis
Stelkast inc.
McMurray Pa. 15129
4 REPLIES 4
ASME B1.1 calls for the nominal sizes starting at ¼" and up as ¼, 5/16, 3/8, 7/16, ½........
Same holds true for the machinery handbook & Federal Standard H28A
I don't know the way you're leaning, but it appears Pro/E is notating them correctly. If you're leaning toward the standard, tell your boss to stick to managing and let you do what you do best. I've never heard anyone suggest that threads should be a .250-20 designation.
Jeff Horacek
Sr. Designer
[cid:image001.jpg@01CB92F1.AB6EF3A0]
STERIS Corporation
5960 Heisley Rd.
Mentor, OH 44060
(440)392-7721 P
(440)392-8954 F
BenLoosli
23-Emerald II
(To:FredMatthis)
ASME Y14.6-2001 is the standard to reference
Thank you,
Ben H. Loosli
USEC, INC.
M6x1 🐵
Hello Fred,
I hope this helps, 1 & 2 are acceptable not 3. If you need to change it, go to the UNC.hol and UNF.hol files located in the <load point="> \text\hole directory. The 1st column FASTENER_ID is how the thread will be called out in the note if you show it on the drawing. The following is straight from ASME Y14.6:
My supervisor and I are having a "discussion" about how a threaded hole or shaft should be shown on a drawing.
We would like to know what is the correct way to show the thread call out on the drawing.
Fred J. Matthis
-<">mailto:->
Stelkast inc.
McMurray Pa. 15129
Karl Krahmer
Mechanisms and Structural Systems
ASRC Aerospace Corporation
Kennedy Space Center, Florida 32899
Mail code ASRC-5211
Office: 321-867-5052
Fax: 321-383-4144
-<">mailto:->
