trying to Loft a 3 axis curve surface for a helicopter windshied
mchristensen
7-Bedrock
This is for a 1949 military help - Skicorsky HS-03 Dragonfly.   Have measurements of the frame of the windshield and can model it in 3 orthogonal planes (X Y Z).   Each has a curved arc which touch at the corners - pairs like XY, YZ, XZ.  When I try to make Matchlines get errors that indicate the point not in plane must have corresponding point.  Not sure what this is telling me.  Is it because the corners of the arcs do not lie in the paired planes?  Not sure if I can do separate Matchlines or in one operation (add to part).   I can attach .PKG file if someone can help.
Mick in San Diego
2 REPLIES 2
I see you tagged this as "Direct". Is this in Creo Direct or Creo Elements Direct? They are different (and I'm not familiar with either) and Creo Elements direct has it's own forum, located outside the "PTC Creo" area here:
Browse > Communities > Creo Elements Direct
I had to filter the Communities list by "Direct" to find it.
Or just use this link, but I wanted you to know how to navigate there in the future.
LinkedIn
Doug,
Thanks a million!   I have Creo Elements Direct ver 6.0 (the free one).   I worked for HP during the transition from their homebrew cad, which eventually was sold to outside (CoCreate) and then bought by PTC.   Same basic look and feel but so much better now.   I use the system on my home PC to do my woodworking and other projects.   Of course, can't afford a maintenence contract, but love the community approach.
Thanks again for the heads up,
Mick
