Paul
Have you tried making two curve sketches with the second a discrete distance from the other. Next you should be able to select which curve you want your sweep to reference. I'm sure this is a series of sketches or series of points with the curve running through points.
Eric Mills
Design and Project manager
http://www.rapidoconsulting.com
eric.mills@rapidoconsulting.com
Ok.... no idea what just happened. My reply WAS:
Do you have Pro Piping? This can be done as a flexible tube in Non Spec Driven piping. We use it for things such as air hoses, etc.
Chris BennerPaul,shoot me an e-mail with your part.
F
In Reply to Paul Korenkiewicz:
Thanks for the additional suggestions... they pretty much centered on what follows...
I wasn't able to eliminate the end issues with a VSS... though, I will admit to always being a bit confused over all the projection references...
I was able to put some points on the edge of my "ribbon", then create a new curve thru those point and set the tangencies at the ends appropriately. Using those curves for my sweep cleaned up the end issues BUT the distance between the curve that was supposed to be constant, wasn't and was a bit lower... so far the best "work around".
Another thought I have been trying to work out is controlling the "ribbon". It's just a VSS of a line with the angle defined in a relation as 90*trajpar. Trajpar goes from 0 to 1, so this relation sets the angle as a linear progression from 0 to 90. BUT what I really need is to force the ends to be tangent. So I thought I could use a sine function to do this. I got as far as converting trajpar to an angle from 0º to 180º, then the sine of that goes from 0 to 1 back down to 0. I thought I could use that multiplied by the linear slope and get just what I wanted. I have been playing around in excel trying to get it to work, but seem to be missing something... What I have is show below with the "RED" sketch what I really need... Any suggestions?
Paul Korenkiewicz
FEV , Inc.
4554 Glenmeade
Auburn Hills, MI, 48326-1766
