turn off x-section lines
ptc-154724
1-Newbie
We are using WF4.0 now, and would like to see if there is an easy way, when you have assemblies (especially larger ones) to turn off (maybe a toggle) all the cross hatch lines without having to go through each component and revising each set. The exclude component does not do what we are looking for, as it removes that component from the section.
1 REPLY 1
For WF4 select the hatching and in the MOD XHATCH menu select X-Section at the top and Erase about 2/3 of the way down the menu. Select Show to add the hatching. You can also erase and show the XHATCH using the pop-up menu accessed by the right mouse button.
