Terry
Create a relation that could be named sum such that the equation would be
sum=d1044-d1043+radii(need the real d#)*2 make sure you verify relations before closing relations tool window.
Then call out the parameter sum on your drawing.
Regards
In Reply to Terry Thomas:
I have a drawing table that has all of its values comming from the part. I want to take and &d - &d to get the value in my drawing. I have tried relations and I am getting errors. This is what I am trying to get to output the correct valve in my table "(&d1044-&d1043) plus the corner radii *2. How can I do this?
Eric Mills
Design and Project manager
http://www.rapidoconsulting.com
eric.mills@rapidoconsulting.com
