The quickest way to get the parameters is to do info from the cutting tools setup on an existing tool of the same type. that lists all the parameters of that tool type
Hi, When using the lathe functions of Pro/manufacturing, I only see one turning tool type available.Is there a path to set to access a tool library?may somebody mail me "ptc turning tool store??" f4rh4d@live.com thnx
