Hello again proe users....
I may have not explained myself in my previous post, so I will add an image this time.
The attached image corresponds to the surface of a spoon I´ve been working on for some time now.
I need to thicken the quilt, however I must have different thicknesses for the bowl (1 mm) and the handle (1.5-2 mm), I also need to be able to control how the thickness varies between the two values.
any thoughts or ideas are appreciated, best regards
Al.
