what does "var elements" (optional) mean in UDF creation dialog?
I can`t undersatand this neither from HELP nor by trying.
var elements means things you can vary during the UDF placement, features dimensions, placement dimensions
and many other.
Hello @ifomenko
picture bellow describes some basics about symbols grouping and variables. More complex symbols are defined with thise two abilities in order to reach predefined statements.
Variables:
- name of text string that will be variable is defined between slashes - \\
- define preset values in SYMBOL DEFINITION ATTRIBUTES window (you can also lock ONLY PRESET VALUES)
Grouping:
- more complex symbols are like "hairy pile" of variable texts (see purple frame in picture above)
- due SYMBOL DEFINITION ATTRIBUTES you can filter what to show / hide
- due Variables you can set desired value for specific part of symbol, that has been filtered in grouping
Conclusion:
Variable is used for more complex symblos with predefined values.
Hope it helps
