what is the recommended screen resolution for creo elements / thunderbolt display
tnugent
What is the recommended screen resolution for a thunderbolt display using creo elements direct modeling?
I'm experiencing a lag in rotating model.
Computer has previously been connected to multiple displays with no problem.
ndodelova
(To:tnugent)
Do you want to use the programm on full 2560 X 1440 resulution (WQHD standard) ?
We are using Creo Elements/Direct on Full HD resolutions (FHD standard) with with 1980 X 1020 (16:9) without any problems.
Did you try to work on FHD resolution, to see whether the lag in rotating still exists ?
