I attached a video showing the problem with selection of a face or a plane. The software lock every time I select a face or a plane.
Please someone help me.
It's likely simply a video card problem. You can test if it is a video issue by adding the following to your config.pro file using a text editor and restart Creo.
graphics win32_gdi
If that solves the issue, it is definitely a video card issue. You can try updating your video card drivers and remove that line from the config.pro file.
