wildfire 5.0 not working properly
ptc-2306411
I am trying to run wild fire 5.0. I running windows 7 64 bit. The program loaded and I am able to open it. However the program does not function properly.
When I open .drw files the view border changes color as if I was selecting it and then it slowly disappears and when opening assemblies or parts the edges of the parts will also change color and slowly diappear without selecting them.The program will freeze until the edges go back to normal. This happens every one to two minutes and makes the program uselss. Does any one know how to fix this problem? I have unistalled the program and did a reinstall and nothing changed. Thanks.
1 REPLY 1
James,
if you are familiar with config.pro file, you can try to add the following option at the end of this file and restart ProE.
graphics win32_gdi
This option turns OPENGL graphics off. If the test is successfull then the problem is related to your graphic card OR graphics drivers.
Martin Hanak
Martin Hanák
