ADAPTER PUBLISH CREO ILLUSTRATE/WINDCHILL
Matteo_1987
Hello to all,
what is the publisher for Creo Illustrate?
I noticed that from version 7.1 there is the possibility to install an adapter.
It means that the windchill worker will create a pvz of all the illustrations
contained in the file.c3di or does it do something else?
Where can I find this information?
Matteo.
vdegaonkar
(To:Matteo_1987)
Hi Matteo:
Yes one can configure worker for Creo Illustrate data (c3di) publishing. Initial support was introduced in Creo View 6.1 (refer what's new ).
Please refer article https://www.ptc.com/en/support/article/CS336248 which explain Creo Illustrate side of configuration while registering windchill server in Creo Illustrate.
Refer topic from Configuring the Creo View Adapter for Creo Illustrate topic from MCAD Adapter Installation & Configuration Guide, which explain how to configure worker.
Also you can refer topic from windchill Server-Side Publishing of Creo Illustrate Data.
Read the following articles:
"How to connect Creo Illustrate to Windchill PDMLink": https://www.ptc.com/en/support/article/CS43807
"A new Direct Link to Windchill option has been introduced in Creo Illustrate 4.1": https://www.ptc.com/en/support/article/CS262259
vdegaonkar
(To:Matteo_1987)
Hi Matteo:
