I am using Creo Schematics Release 7.0 and Datecode7.0.0.0
您好PTC 我想请问下在Creo Schematics中可变接插件的entry_port的值无法像name值一样自动根据序号更新名称(如:默认名称为Pin_#,序号为 1,自动更新后的名称为Pin_1),请问有什么方法解决这个问题
如果有解决方案请电话:15527705829联系加工或者邮箱:15071650294@139.com
Translated by the moderation using Google Translate
Hello PTC, I would like to ask about the entry_port value of the variable connector in Creo Schematics. It cannot automatically update the name according to the serial number like the name value (for example: the default name is Pin_#, the serial number is 1, and the automatically updated name is Pin_1) , is there any way to solve this problem?
Hi WC_9256664
Thank you for your question. Since there are no responses yet, I’d like to recommend bringing more details and context to your initial inquiry. It also helps to have screenshots to better understand what you are trying to do. This will increase your chances to receive meaningful help from other Community members.
