Creo crashes after 5-10 minutes with a fatal error message
PascalDICHELLO
Creo crasher after 5-10 minutes with a fatal error message (tracebak.log)
Can you help me please
The trace creation timestamp is: mer. mai 26 10:04:59 21
The executable build timestamp is: mer. sept. 26 10:48:51 18
The datecode is: 2018260
The pro machine type is: x86e_win64
The process ID is: 2020
The traceback type is : CRASH
The logger exit status is: 00003
The Trail is: trail.txt.49
The release is: 5.0
The product version is: 5.0.2.0
The product title is: Creo Parametric
Exception EXCEPTION_ACCESS_VIOLATION has occurred in the thread 23336.
Hello
In order to help you with this issue,  I propose to open a case.
This will allow you to attach the traceback.log file and  the corresponding trail.txt file for furthur investigation.
Can you provide your SCN number please.
Best regards
Jean Claude
