Are there any additional default system functions to be used for creating derived parameters other than the following:
dg_inherit_from_ancestor
dg_inherit_from_connected
dg_derive_from_enclosure
dg_derive_indirect
dg_derive_indirect2
dg_derive_as_label
Can any of these be used to propagate a property value from one port to another?
Thank you.
Hi @JS_MM
Thank you for your question!
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
After further investigation, my issue is not as specific as my initial request.
Should I continue to explain what it is that I'm looking for in this thread, or start a new thread more specific and detailed to my issue?
