Is it possible to add a hyperlink in a callout in creo illustrate ?
Article - "How to define hyperlinks or hotspots in Creo Illustrate": https://www.ptc.com/en/support/article/CS130375
Hi, you cannot set this to solved, when the referred article says there is no such function in Creo Illustrate!
This is misleading/a waste of time for any user.
Please correct or at least add a link to "is in work in product development etc."
Besides that why is there an option in the save as SVG called "Include hotspots for callouts"...
Kind regards
Tim
