Publish Illustration files from Creo Illustrate 6.1 to Windchill
Saurabh_Ch
2-Explorer
  1. How to publish .pvz, .cgm, .svg illustration files from Creo Illustrate 6.1 to Windchill?– It is showing error – “Publishing to a server location is not supported.”
  2. My requirement is to save these files in Windchill.
1 REPLY 1
Server side publishing addresses this by automatically taking the published contents and associating them to the representation.  You can also use the post-publish delegates to move them into separate business objects as desired.
I would suggest contacting your Windchill admin team to help set up the server side publishing.
