Viewing 3D notes on Models in Creo View
ptc-4136280
Good Afternoon,
Would anyone know what you need to do to view 3D notes put on a model in Creo View?
Thank you,
Lori Bonser
Lori Bonser
Senior Draftperson, Patterson-Kelley
Harsco Industrial
155 Burson Street
East Stroudsburg, PA 18301
Office 570.476.7315
Fax 570.476.8637
6 REPLIES 6
mlocascio
(To:ptc-4136280)
Layers? Filters?
Lori,
You need to publish thru a cadworker because it will give you the best results for annotations on a 3D model. Save As in Creo does NOT give you the same results as thru a Cadworker.
Lance
Lori,
Just like Lance says, here are the settings for the Cad Worker recipe file.
[cid:image001.png@01CF4A9C.78CB0B80]
Anthony Mahynski
Advanced CAD Development Specialist
Engineering Services
hermanmiller.com
I had thought Creo Parametric uses a flavor of a recipe file when doing a save as. In the MXXX/apps/prodview folder is proe2pv.rcp.
Mark
Mark Ganzer
Technical Account Manager
EAC Product Development Solutions
1-888-225-7579 ext. 169
Using two file explorer windows you can drag this file
"<path>\Mxxx\Creo 2.0\Common Files\Mxxx\text\prodview\export_pvs.rcp"
over
"<path>\Mxxx\Creo 2.0\Common Files\Mxxx\apps\prodview\bin\rcpedit.exe"
to edit the recipe file used for Save As to Creo View.
This lets you export annotations.
Remember to setup CreoView to show annotations as well.
[cid:image002.png@01CF4D82.1EB50220]
/Bjarne
Lori,
Here is the hierarchy breakdown for creating a Creo View file as each one will give a different result. We did some heavy investigation into each one this subject when I was with Raytheon.
1. Publish thru a Cadworker with Windchill PDMLink
- Best results
- Closest to WYSIWYG
- Still needs improvement
2. Install the Creo View Adapters with Creo Parametric
- File, Publish to Creo View from Creo Parametric menu
3. File, Save As, .pvz in Creo Parametric
- Missing annotations and combined states
Lance
over
/Bjarne
