Tried placing Decals on models...they must be invisible? Went thru the prompts, searched in the HELP section, did the Mapping Shape and wore my tin-foil hat for a bit...???!!!
It's on a flat surface and the model is brought in as a STEP file?
Screenshots show the application of the decal...invisible.
Hi @TG_10622756,
Thank you for your question!
Thanks for using the Community!
Best regards,
Without seeing the data it is very hard to say what is causing this.
I would recommend logging case with tech support so it can be properly investigated.
