Where's my Decal?
TG_10622756
Where's my Decal?
Tried placing Decals on models...they must be invisible?  Went thru the prompts, searched in the HELP section, did the Mapping Shape and wore my tin-foil hat for a bit...???!!!
It's on a flat surface and the model is brought in as a STEP file?
Screenshots show the application of the decal...invisible.
Hi @TG_10622756,
Thank you for your question!
Thanks for using the Community!
Best regards,
Catalina
PTC Community Moderator
PTC
Without seeing the data it is very hard to say what is causing this.
I would recommend logging  case with tech support so it can be properly investigated.
