Accessing model .prt after running a CFD flow analysis
JBB76
11-Garnet
After I run a flow analysis on a part, (Creo 9.0) I am unable to open the part again. When I try to open the original part, I get a blank screen of the planes of the part, not the part as originally constructed. Please see below.
Any insight would be helpful. Thank you.
Martin,
Thanks so much for the obvious. I appreciate your helpful perseverance. I found that showing the Body1 and the Merge revived the model. If I also show the Fluid, I get the fluid domain.
To change the model it seems the only the Body1 and Merge are necessary. These two gave me access to the original sketch. Below is the revived model.
Thank you again!
MartinHanak
(To:JBB76)
  • end current Creo session
  • start new Creo session
  • open part
  • is model displayed properly ?
Martin Hanák
Martin,
Thanks for responding. Unfortunately the model still does not display. If I select the part in the tree, below is what I get; a little more than the planes, but nothing useful to make changes to the model.
MartinHanak
(To:JBB76)
look at bodies items in model tree. They are greyed. I think this means they are hidden. Select them and apply Show command.
Martin Hanák
Martin,
Thank you again!
