Using Creo Parametric 8.0.4.0, is it possible to create an animation using both a servo motor and explode? Attempting to explode/unexplode an assembly, then show rotation using the servo motor. Can these two features be used simultaneously or will separate animations have to be created?
Hi @AB_12662889,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
