Good morning,
I would like to know if it is possible to transfer the results of a static simulation performed with CREO Simulate to ANSYS wor a following simulation which should start from those results (for example, perform a drop test simulation with ANSYS which includes pre-stresses obtained from a static simulation with CREO Simulate).
Thank you for the support!
No, creo simulate results can't be read into Ansys as far as I know
Models can be built using Creo FEM mode, submitted to a remote solver (ansys/nastran), and the results reviewed in the Simulate post processor if you want.
Better to build the model workflow you describe in Ansys from the begining if you want to use the final state of an earlier model to become the input state for the next study.
atb
atb
