I am using the Academic Version of Simulate and I would like that someone (with the commercial version) tries to open either the .prt file or just the result window, I attached both files.
Just in case, remember that (in this case) for the result window you must set as working directory the folder "Results", otherwise it won't work.
Thank you.
Academic & Student files cannot be opened in Commercial session.
MH
What about a results window? The same thing?
I am sorry, I do not know
MH
The .prt file can't be opened with Commercial License.
Howerver, it's OK for the result window
SW
