I imported data from excel in to creo through excel analysis.
But the name for each imported parameter is appearing as XL_4_2, XL_4_3 XL_5_2, XL_5_3, etc.(see attachment)
How can I change the name of these parameters. I want each imported parameter to be identified as some user defined parameter name.
Open the link below and refer to step # 11. at this step you should be able to enter the name as required. If you are looking to automate this then you would likely need to write an app using one of the Creo API options.
To Create an Excel Analysis Feature (ptc.com)
