Component Display Use model in tree
dconnor
Hi All
We have just upgraded to Creo Pro/WF5.0. and we are having problems finding out how to get the WF4.0 function we used to use, as follows Select View RMB Use Model in Tree. We then use the models in the Tree to set Styles ect. In WF5.0 we find the you can Set/Add Drawing Model but this does not give you the option to set the Model tree for a perticular View it just defaults to the Main Drawing View. And to use Query Select in a View is okay when you have a small assembly but our assemblies are 9 out of 10 times 1000+ models making the query select very time consuming. Does anyone have a work around that they are willing to share because this has had a large impact on out drawing production times
many thanks
David
RandyJones
20-Turquoise
(To:dconnor)
On 03/20/11 21:00, David Connor wrote:
> Hi All
> many thanks
> David
In the Model Tree (drawing model tree) select the icon to the right of the text "Model Tree". This is a menu that allows you to select which drawing model to show in the model tree.
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
