Contact interface issue on Creo Simulate 6
LR_8377518
I am using Creo Simulate Release 6.0 and Datecode6.0.4.0
A contact interface with infinite friction on a pin allows material compenetration and gives skewed deformation results. I tried switching from component-component to surface-surface but reached the same results. The issue happens on a particular pin in a specific location, so I tried to delete and re-create the interface but no changes. The geometry is correctly highlighted in yellow on "review geometry" and the mesh completes without problems. Any Ideas on why it is happening?
skunks
(To:LR_8377518)
a very fine mesh is required for good results (att. example) of a contact analysis
skunks
(To:LR_8377518)
JXBWk
(To:skunks)
is your picture shwowing a mesh ? not sure it does 😉
skunks
(To:JXBWk)
no 😀 (very very fine mesh...)
but here
LR_8377518
(To:skunks)
It worked! I reduced the mesh minimum element size by two order of magnitude and the interface started behaving normally. Thank you very much!
