Contact problem
I am using Creo Parametric - Release 6.0 (connected) Release 6.0 and Datecode6.0.3.0
I am working on a spring pin connection to a pcb device. There are two cases in question an both applies this problem the first is when perfect alignment to the via hole occurs. For this case deformation should occur on the edges that the pin contacts the pc yet instead of that overlapping between both assemblies occurs. On the other case the alignment is not with the via but instead only on the plating (similar to an indentation process ) but the pin tip also instead of penetrating and deforming the surfaces the results show overlapping once again
