Hi, i have a problem.
My Live Simulation don't show result, it show 0 MPa, like picture.
I need help because i tried fix but i can't
please read https://community.ptc.com/t5/Creo-Simulation-Live/Simulation-live-gives-results-as-zero/m-p/610896 discussion.
I tried everything in the post, but for me it didn't work
the material is correct, I already tried to configure the working directory even so nothing happens
Video card is updated
Admin mode
C:\Users\<USERNAME>\AppData\Roaming\PTC\Creo ...it's OK
Godoi
Admin mode
Godoi
my suggestion ... report the problem to PTC Support >>> open Case and you will see...
