Creo/Simulate can you have non-linear and temperature dependent material properties
jalexander
I need to simulate a manufacturing process and I need to have non linear stress strain and thermal expansion material properties that are temperature dependent. The material changes state at a high temperature and when it cools down because the thermal expansion coefficients are different in the materials as a function of temperature stress/strains are built into these materials as they cool down which I will simulate with a different regions in the material.
Chris3
(To:jalexander)
Yes you can.
Right click in the property field that you want to add dependency to and choose "Function" Then click the new page button and go from there.
