I am using Creo Simulate Release 6.0 and Datecode6.0.6.0
When trying to run AutoGEM, fails and microsoft visual c++ prompts the following. "Assertion Failed! File s:/sim/common/src/data_mgr/fastener/MechFastener.cxx line 340. Expression: UndefDbid != dbidPreLoadSpring"
Read this article - "Pro/Mechanica analysis fails with message "Assertion Failed! File s:/sim/common/src/data_mgr/fastener/MechFastener.cxx line 275. Expression: UndefDbid != dbidPreLoadSpring"": https://www.ptc.com/en/support/article/cs157250
Thank you for responding.
Thought the lines being different could have referred to a different issue but will look into that. Thank you.
You're welcome.
